heffer
- Jan 2, 2017
- milton
- yamaha rs vector
i just picked up a 2005 rs vector. I took it out the first time on the weekend, and wow...... this thing is Terrible! Serious darting. I have 96 studs in the track and single carbide i think 6" on stock skis. I have read a couple things; but i would like to know how people have corrected this issue..
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
snowtrackers is all I run on stock skis. I would highly recommend them. It will transform the handling of the sled in a positive way!
heffer
- Jan 2, 2017
- milton
- yamaha rs vector
ok thanks. I went from a indy 500 which had no studs/carbides and was easy to ride to this vector which seems like hell.... I was burned out after 20miles and darting all over the place. Pretty disgusted at this sled at the moment. I always thought carbides and going dual possibly was for steering on ice not to be corrective issues for bad engineering?
Deepwater
- Apr 20, 2015
- New Brunswick
- 2011 Vector LTX
Snow Trackers, just make sure you set the suspension as per their recomendationsok thanks. I went from a indy 500 which had no studs/carbides and was easy to ride to this vector which seems like hell.... I was burned out after 20miles and darting all over the place. Pretty disgusted at this sled at the moment. I always thought carbides and going dual possibly was for steering on ice not to be corrective issues for bad engineering?
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Stud Boy Deuce bars work well on the stock skis. I also like to shim the rear of the ski rubbers 1/8" to 3/16" to get the tips up a little more.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Aggressive SnowTrackers is your answer. Best money that you will ever spend on your sled. No shimming or messing around, just one hole to drill in your ski to install, all very easy.
MadMax
I've ran duece bars for 11 happy years. My two buddies also run them........MM.
Indy
skis need shimmed, and the front pressure needs to be reduced. This will make it better, but not as good as snowtrackers.
heffer
- Jan 2, 2017
- milton
- yamaha rs vector
anyone rode the vector without studs and say standard wear bar, bone stock condition...? any difference there at all without studs/carbides?
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Sure, I still have my 05 and new from the dealer it had 144 studs in it (never again)....2nd track has no studs. Dual runners (never tried Snow Trackers yet) will solve your problems. 6" carbide length. Shim your skis as well. 1/8" - 3/16" thick shims will do the trick. If you can find one install a heavier sway bar too. Better, flatter cornering.
heffer
- Jan 2, 2017
- milton
- yamaha rs vector
So you prefer no studs; why? Was it still squirrely without the studs as well?. I just put 1/4inch shim on this afternoon, I tried to upload pics but the site said they were to large of size. I am trying to figure this machine out; I just never had one handle so wild on a trail before.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
You have mail. Studs made no difference when it came to a sled being "squirrely". That's all in the skis and runners.
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Had the same issue on mine. Put the stud boy duece bars on like above............problem solved.
Indy
The main reasons for studs are BRAKING and traction. I ran 1 season without studs, not again. Rear end would be "squirrely" on hole shots and braking without studs. You will get more front end push with studs, Snowtrackers will solve this issue.
