wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
Been a great sled for 12 years. Today it started to run fummybthen quit. Retired and as soo as you gave it gas would die when giving gas.
Fuel pump cycles. One thing I noticed was when I cycled key with fuel cap off could hera fuel running in tank. Is this the return fuel ?
Also if i remove belt engine will rev up to 10000 rpm no issue as soon as belt is on clutches when you rev to take off dies. Tried it twice belt on and off same results 2 times. I dont have a volt meter with me to see if I have charging issues. It's not a Tors issue as it dies when giving throttle
Any thoughts?
Any thoughts?
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
The belt is confusing, is it a motor issue or drivetrain issue? Example- secondary is locked up or something?
Check the drive bearing/speed sensor.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
X2Disconnect speed sensor and limp it home.
wkeggenhoff
- Dec 20, 2007
Pulled sled apart last night. you guys were correct. Drive axle earing is hooped, took out sensor
I've heard of them putting up code but not killing engine altoggether
It was only 2 years old and I repacked before I installed
Did have a 20 km mud road we ran last spring, guessing got full of water/dirt and then sat in there all summer
Going to have to service this bearing in spring before I put in storage this year
thanks for your help guys
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
End of each season repack all bearings in skid wheels, driveshaft and jackshaft and will never replace a bearing ever again. 8k on my Apex's on the original bearings. My son had 14k on his RX when we sold it by following this service of the bearings each year.Pulled sled apart last night. you guys were correct. Drive axle earing is hooped, took out sensor
repack that bearing every fall before the season and the one on my 11 made 11000mi before it cut the race in 1/2 on it when it failed. i repack the skid bearings on my main trail sleds every year. the other sleds i check and repack when needed as they are not ridden as much. they seem to get 2-3 seasons in the aux/back up sleds before they need attention.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
It’s a $30 bearing, all of my rides get a new one every fall......just say’n.
It’s a $30 bearing, all of my rides get a new one every fall......just say’n.[/QUOTE
Taxes in
when i get one with the tin sheilds, yes i replace it every year or 2. the rubber seal ones i check and repack every year. gets not cheap when you have to pre season 6 sleds every year at minimum for myself.
They would last way longer if they had that moisture protection seal with drain like the Winder has in there.
