Jimk
- Jan 6, 2013
Dash goes blank, but lights stay on and engine keeps operating without issue. After a while the dash goes back on intermittently. anyone have ideas?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Have you removed the headlight pod recently. Check your speedo bearing for failer, but most likely its the connections under the headlught pod.
triple777
Had the same issue in my 06 did the typical test myself wiring connectors, power and ground ended up finding short in gauge pod switched with a buddies apex when it acted up, pod bad took it to dealer because i had extended warranty and they trouble shot replaced computer and sent me on my way still acted up took pack then finally replaced gauge pod check ebay cheapest bet
Jimk
- Jan 6, 2013
I have headlight pod off and have been moving wiring and can't reproduce problem. How would speedo bearing affect dash power. I am beginning to believe I have a bad ground. does the Apex have a common ground lug?
Here is a link to the ground block issue
http://www.ty4stroke.com/viewtopic.php?t=83994&start=0
Jimk
- Jan 6, 2013
I found the (2) ground blocks by primary clutch
Still looking for other ground blocks. Re-soldered (2) by clutch and still have no dash power.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Re: I found the (2) ground blocks by primary clutch
I have a spare speedo I could mail you to test.
Jimk said:Still looking for other ground blocks. Re-soldered (2) by clutch and still have no dash power.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
if the spedo berring was destroyed it would eat the speed sensor and cause a shot and that has been known to cause the dash to go blank.check fuses as well.otherwise it sounds like the above mentiond prob with the pod take up team blue on his offer if you dont have a friend near with one to try swaping.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Has the speedo wire harness been modified? I ask because I have had my speedo on the handlebar riser on both of mine.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
The other block is over by the cooling system water bottles.Jimk said:Still looking for other ground blocks. Re-soldered (2) by clutch and still have no dash power.
Jimk
- Jan 6, 2013
Dash for loan
Team Blue4-I'll take you up on the loaner dash offer. can you call me at 619-973-5688?
Jimk
- Jan 6, 2013
TeamBlue4-phone no incorrect. Correct no is 618-973-5688.
