VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
I wanted to share my experience this season with my '06 Apex GT that's been transformed into my own version of an XTX. Since this sled is the first year of the Apex based platform it doesn't have the lastest and greatest features like EPS and EXUP but it does show that with some mods to an older sled you can still have some fun on the slightly older iron.
Here's a list of some of the changes that have been made to the sled:
1. Pioneer Performance Front Wideing Kit. I installed this kit a few years ago. It increases the ski stance from the stock 42" out to 45". It's also about 3 lbs. lighter than the stock A-arms. I'm not sure if Pioneer still has these kits available or not, but it really has made a difference in improving the handling on the sled. You can rail the corners and the added straight line stability at high speeds in nice. I've had zero problems with this kit. Also running a 13mm sway bar.
2. Fox Float X Evol Shocks. I had these custom built a few years ago before Fox had these shocks available for the Apexes. I've since upgraded them with the Kashima coated bodies. With the clicker adjustable low and high speed compresssion damping and the clicker adjustable rebound damping you can really fine tune these shocks. Being able to adjust the air pressure in both the main and evol chamber gives you even greater fine tuning adjustability. I'm very pleased with the ride quallity of these shocks. They are extremely plush feeling and still offer great control and handling.
3. Slydog Trail Skis and Bergstrom 8" Triple Point Carbides. I've had great handling results with these skis and carbides. I also have shimmed the skis to provide a neutral front/rear balance and run the Bergstrom ski savers. With some fine tuning of both the front and rear suspension you can have great front end bite with minimal ski pressure. My shoulders don't hurt afer a brisk paced 200 mile day due to the light steering effort.
4. Yamaha XTX 144" Skid. I really like what the 144" length does for the Apex. The increase in traction gives great acceleration along with bridging the bumps. I've installed the Dupont hyfax along with swapping out the stock wheels with Excell wheels and also added a additional set of small wheels at the front bend of the rails. I also added some extra wheels behind the rear bump stops. So far the hyfax wear has been very minimal and even this season along the whole length of the rails. I did notice that some TY members were having some problems with limiter straps breaking on both the Nytro and Apex XTX skids. I doubled up the limiter straps according to another members advice and haven't had a problem. I keep on eye on the limiters before every ride and so far I haven't seen any signs of wear or breakage on them.
5. Ohlins 46PRX shocks on skid. I got these from TY member Bjowett. They have clicker adjustable low and high speed compression damping along with clicker adjustable rebound damping. I really like the adjustability to fine tune the ride as conditions change along with no shock fade. I also replaced the rear stock torsion springs with some titanium springs that I had on another Yamaha torsion style skid. This spring has a higher rating than the stock spring and has worked out great with this shock/skid set up. I also replaced the torsion spring adjuster block with a billet X-Click adjuster that has 4 positions to set preload vs. the stock plastic 3 position adjuster block to fine tune the preload.
6. Star Suspension XTX Linkage Kit and Star Rear Shock Pull Rods. This kit has really improved the weight transfer of the XTX skid along with greatly improving the stutter bump compliance. It has also helped eliminate most of the rear sag issues that the XTX skid is known for. I really like the transfer with this kit when accelerating and also the rear to front transfer when lifting the throttle for some extra ski bite coming into a corner. By adjusting the air pressure in the Fox shocks to allow the a-arms to be slightly higher than parallel with the ground the steering and handling has greatly improved with no loss in comfort. The Star rear shock pull rods are nice and beefy and are a nice replacement for the stock steel rods.
7. Camoplast 1.5" Lug Crossover Track. I installed this track over the stock 1.25" Ripsaw that comes with the XTX. I chose this track after reading some reviews from fellow TY members. I don't run studs and in the conditions that I ride in, mosty hardpack with some off trail it has been a excellent track choice for this sled. Absolutely no tailwagging or fishtailing on a high speed hardpack or loose straight stretch and awesome grip on acceleration. You still need to watch yourself in icy conditions but I love this track for most every condition.
8. Muffinworks 144 Tunnel Extension. I've worked with Jason at Muffinworks on a few other extensions in the past and their extensions always fit perfectly and look nicer than the stock Yamaha extensions. They also use a thicker gauge aluminum than the stock extension for extra strength.
9. Heel Clicker 2-Speed Weights. This is the first year that I've tried these weights and I'm extremely impressed with them. Thanks to some fellow TY members who posted some of their set ups using these weights I was able to get them fine tuned for this sled with minimal tuning. With my current set up it's got a nice low engagement speed with awesome acceleration and top end pull. There is a very noticeable change in the performance of the sled with these weights compared to the stock clutch set up. I've found a 23/40 gearing ratio to be perfect for my set up.
10. Yamaha Tunnel Support Brackets. These really help strenghten the tunnel/running boards from flexing. Some older Apexes have developed problems with heat exchanger cracking do to running board flex and these brackets totally eliminate the flex that causes the cracks. They also have some needed added traction grips on the running boards.
Everyone has there own likes and dislikes in what kind of skid and track length is best for them in the conditions that they ride in. Some will like the scapel like handling of a 121" or 128" Apex with the mono skid, and the plushness that the mono skid will give. My wife drives a 136" Apex with a mono skid that has a Ohlins shock with the PDS mod. That skid can be set up for a super plush ride. We've been tuning on that sled for years and it's hard to beat it for a super smooth ride.
The 144" XTX skid will be slightly firmer than the mono skid from my experience, but can give some extra benefits that the mono skid can't give lilke bridging the bumps better and some extra control when the speeds get higher, in addition to the extra traction and floatation. You're going to give up some of the razor sharp handling, but in my humble opinion it's hard to beat the complete package that a Apex XTX delivers, especially with a few other mods to the sled/skid. I love this motor/skid combo. Kudos to Yamaha for coming up with the XTX Apex package.
Here's a few pics of how the sled turned out:
