Mikedom
My stock primary on my '06 Vector GT is shot. Instead of rebuilding it, I was looking at putting a low mileage used primary on. What years and models (Vector, Apex, etc) would be a direct bolt on replacement without changing weights and springs? I want the same stock clutch setup as I currently have.
Thanks!! Mike
Thanks!! Mike
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
All will fit, but they may have different diameter rollers, primary spring and weight arms. I guess all Vector clutces is pretty much the same, the Venture would be different and the Bad Boy Nitro will also be different.
A primary clutch from any of the 3 and 4 cylinder 4strokes will do. Move over rollers (change bushings if needed), buy a new primary spring to replace the old stock one, inspect the stock weight arms - if good replace bushings at the pin hole.
hossZ28
Still has a yamaha powerplant!
- Feb 6, 2009
- Ontario Canada
- 2014 Arctic Cat XF 7000 LTD
If you have to go why not pull the primary and rebuid it it wil save you the price of the 2nd clutch
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
A rebuild will not take care for worn out clutch faces I would assume.... hahaha I'm speculating here
Mikedom
Yeah, unfortunately the clutch faces are dished and grooved really bad with only 5000 mles on it. Thanks for the reply. This will help.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Mikedom - If you have any questions feel free to ask on here or thru PM.
Would you mind filling in your location in your user profile, it's a site requirement.
rxrider
TY Management
rxrider
TY Management
