Lalonde174
- Jul 7, 2016
- Ottawa, ontario
- 2010 Yamaha rs Vector l-tx gt
Hello everyone, I just bought a 2010 rs Vector l-tx gt, and I'd just like any advice I can get in terms of if anyone know what any problems are with the sled, I need to know if there is anything I should look for or change in case this model has any problems, I know that the primary clutch is loud on all these sleds and is there anyway I can make it quieter?
Thanks, jake
Thanks, jake
Lalonde174
- Jul 7, 2016
- Ottawa, ontario
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
There are, but usually only last for a short while, so not worth it in my opinion. The clutch is only noisy at idle anyhow, so pound the throttle and forget about it. Welcome to the site, see you on the A trail.
Welcome to the site. Some upgrades I would do is HID lights and maybe hand and thumb warmer booster, Skis with Slim Jim Duallys or just the dually on the stock ski. Other then that, the Vectors are great sleds and usually pretty trouble free.
Lalonde174
- Jul 7, 2016
- Ottawa, ontario
Ok thank you
Lalonde174
- Jul 7, 2016
- Ottawa, ontario
Thank you for your help
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Thanks, jake
Welcome ! I feel your sled is one of the best trail sleds made. 2010 had many upgrades. I will list a few good subjects to research to make it better.
Ski's : I like a wider ski for flotation on these front heavy strokes, but you can make the stock ones work just fine!
Carbides on stock ski's : the Slim Jim's are very good like Mr Sled suggested, Snow trackers work excellent, Bergstrom Triple points are awesome, Shaper bars with the Half pipe mod work well too!
Shim's on the ski rubbers: cure for Darting !
Soft start Primary spring: Smooth starts with no lost of top end , look under Barn of parts He has them cheap!
2" riser for the Handle Bars: excellent upgrade and not to pricey
Dual rate springs for the Mono shock: Best upgrade I did for the rear suspension!
over sized Idler Wheels: cut down on slider wear!
Research how to set them up to rail the corners: Do a search or just Ask if you can't find it.
HID head lights: Very good upgrade if you ride at night!
I'm sure people will add to the list ! LOL !
You can spend a lot of money or very little it depends on what you like to do.
Enjoy one of the best sleds made!!
DGZRT
- Feb 23, 2006
Forgot a few things.. look at all the sticky notes on top of the RS forum ton's of good advice. one Important thing is If your going to stud the track make sure to add some UHMW to the back end of the tunnel protectors or you will tear up the back cooler .
Lalonde174
- Jul 7, 2016
- Ottawa, ontario
Thank you for the suggestions
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
How many miles on your sled? Check for play in the A-arm and torsion rod bushings. Also check for play at the bolt that connects the ski to the spindle.Thank you for the suggestions
As mentioned, the Vector is a great sled! Lots of of great suggestions above and lots of great people on this site willing to help!
Lalonde174
- Jul 7, 2016
- Ottawa, ontario
2010 vector with 6250km on it
Redbeard
- Oct 14, 2011
- IN
Shoot...she's not even broken in yet!2010 vector with 6250km on it
Lalonde174
- Jul 7, 2016
- Ottawa, ontario
Shoot...she's not even broken in yet!![]()
I know, the track isn't even studded so I don't have to worry about that either
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
welcome....and just a couple items to check, have had a few vectors in the family fleet. a couple things to check at your mileage are the front end bushings and exhaust donuts. and front end set-up will make a world of difference in handling also. we have run snowtrackers on all of them FYI
Lalonde174
- Jul 7, 2016
- Ottawa, ontario
Ok thank you
