T.O. 2008apex
- Apr 14, 2020
- Michigan
- 2008 Alex ltx 40th anniversary
Went to start sled today. Turned key. Pump cycled. Dash did its thing . Absolutely nothing after that. Held key in start position for a few seconds then decided to start right up. New battery. So not the issue. Is there a relay that can get corroded and work after a few seconds? Thanks.
The starter relay is along side the battery. I would also check to be certain the battery cables are tight. I have found that the cables can loosen so maybe a little blue locktite on the cable bolts
You could also check the ignition switch,it might be that it has some corrosion on the plug
T.O. 2008apex
- Apr 14, 2020
- Michigan
Thanks I will check those things. I did have the dash off before trying to start it. So the plug by the key could be the culprit.
