well the issue seems to be getting better with time. the more I ride it the less it happens. last 2 rides it wasn't happening anymore at all. I started using Yama lube fuel conditioner, and injector cleaner in the last few tanks. I've got to believe it was either bad gas, or clogged injectors. I checked the harness there is a rub mark on the wire loam around the harness, but it hadn't rubbed through. (I Tie-wrapped it out of the way so as to avoid future crap)
an other thought occurred to me, when I open my gas cap, I hear a wshhh of pressure releasing. how is the tank vented? this would explain why the issue only shows up after a 1/4 tank, might be creating a vaccum and starving the motor of fuel? is such a thing possible?
