onceunder
- Jan 29, 2023
- adirondacks
- 2008 Nytro
Hello sled was running fine, stopped and went to start heard a click died no power....power came back on with ER 1 code checked wiring got a used ecu and same issue....... so when i hear the fuel pum come on and try to start the starter relay click and all lights go out. Any Idea? thanks
Most likely one of the ground blocks located in a few places in the wiring harness. There are also circuit connector blocks for other color wires that can give as much trouble.Hello sled was running fine, stopped and went to start heard a click died no power....power came back on with ER 1 code checked wiring got a used ecu and same issue....... so when i hear the fuel pum come on and try to start the starter relay click and all lights go out. Any Idea? thanks
onceunder
- Jan 29, 2023
- adirondacks
- 2008 Nytro
thanks, any chance you know how many ground blocks ?Most likely one of the ground blocks located in a few places in the wiring harness. There are also circuit connector blocks for other color wires that can give as much trouble.
No, not off the top of my head. But the grounds have solid black wires.thanks, any chance you know how many ground blocks ?
onceunder
- Jan 29, 2023
- adirondacks
- 2008 Nytro
ok thanksNo, not off the top of my head. But the grounds have solid black wires.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Check the main ground wire from the battery. There is a spade connector that can corrode and/or become loose.
- 6K
