mebelee
- Dec 21, 2014
- 2010 Yamaha Vector GT
2008 Yamaha Vector GT
2020 Yamaha SnoScoot
1979 Arctic Cat Pantera
1974 Chaparral SSX
1997 Polaris Ultra SPX SE
- Barnesville, PA
Replaced the ENTIRE fuel circuit, from filters to carbs, pumps too, fuel lines ,vacuum lines ! (included a new choke cable). Damn thing was a bitch to get started...no fuel in bowls initially ??
Warmed up fine, after a tweak to the idle screw. AS soon as any amount of throttle, she stalls. Starts right up again ( engine is at operating temp), but as soon as any gas is given... shuts off. Where did I go wrong ??
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Stupid question, but have you synced the carbs?
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Possible TORS issue?
mebelee
- Dec 21, 2014
1974 Chaparral SSX
- Barnesville, PA
no i had planned to but I was thinking that something else was wrong and I should fix that first ??Stupid question, but have you synced the carbs?
mebelee
- Dec 21, 2014
1974 Chaparral SSX
- Barnesville, PA
Yeah I did, used the gauge I made with the help of a fellow ty4er. Worke GREAT - took VERY little turnage of the adj screws. Had to go back and forth a few times between # 1 & #2 but finally got it dialed in, I think. Off idle stalling till persists, though.Stupid question, but have you synced the carbs?
mebelee
- Dec 21, 2014
1974 Chaparral SSX
- Barnesville, PA
Well, that may be the issue, carb sync went fine.Possible TORS issue?
Still stalls , or wants to when I feed it. How do you trouble shoot the TORS?
for test purposes only! you unplug the wires going to the block under the idle adjustment screw and plug them together. if it runs bypassed, you need to check throttle freeplay as that can cause it to activate when the throttle cable is too tight.
mebelee
- Dec 21, 2014
1974 Chaparral SSX
- Barnesville, PA
Tx give it a try tomorrow
thrasher
- Nov 22, 2006
- 06 Vector RS ER
Carbs and jets need a good cleaning if haven't done so, or are brand new?
mebelee
- Dec 21, 2014
1974 Chaparral SSX
- Barnesville, PA
Thanks. Carbs are used- took off bowls all looks clean inside.
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
These sleds are notorious for plugged pilot jets.
mebelee
- Dec 21, 2014
1974 Chaparral SSX
- Barnesville, PA
Looks like it's a T.O.R.S. issue. 2008 RS Vector. The only electric plug I can see is on the "other" side of the carbs opposite the adj screw. FOUR wires - how do you test it ? Thank you !for test purposes only! you unplug the wires going to the block under the idle adjustment screw and plug them together. if it runs bypassed, you need to check throttle freeplay as that can cause it to activate when the throttle cable is too tight.
it should only be a 2 wires sharing the same loom. that 4 wire sounds like the tpms sensor plug.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Maybe this will help.
ty4stroke.com
TORS problem
I think this is the way you bypass the TORS on the VECTOR See the pics below. There are two plugs, one white and one black, they each have a single wire in them. Unplug them both and plug the two that come up from the engine compartment together. TORS is bypassed... I think this is the...
ty4stroke.com
