NytroJo, if you can, please post a picture. I also have ice problems. It is a 1.75 back country with tunnel protectors removed and a mountain heat exchanger near the front of the tunnel. The front of the tunnel was clear, but the last 32 inches which is exactly from the muffler to the back bumper was a solid block of ice over 4 inches thick. I am thinking of installing approximately 15 X 32 inch 2mm plate aluminum suspended about an inch under the muffler and cover the bottom side with blueskin, the stuff you use on your roof for eaves starter. Slick like goose...., I am anticipating that nothing will stick to that stuff, nor should the blueskin ever fall off. Once its laid, its there for keeps. Not sure when this will happen, but it will, but if someone beats me to it, please post the results.
