wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
Newphews sled wont go into reverse unless you jump up and down on seat.
When yopu push button indicator comes on and back up alarm but sled revs up but wont go any where. Is there an external adjustment for this.
We have no ops manual or shop manual
Thanks Werner
Thanks Werner
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Make sure the idle speed is around 1800. If the idle is too fast it wont want to shift.
If that is good check to make sure your running the updated belt 8GK-17641-10-00.
If you have that adding a shim in the secondary to drop the belt height will help with shifting.
