muffinboy
- Oct 10, 2024
- Kipnuk
- 2010 Yamaha Nytro MTX
So I have a 2010 yamaha nytro, brand spanking new battery but clicks when I turn the key. I've tried jumping the solenoid to see if it would crank but no crank so maybe starter too? Also has a code 37 on and found a wire that was in two, so I reconnected the wire. Still has code 37 but never got it to crank it just clicks.
I would guess start went.
muffinboy
- Oct 10, 2024
- Kipnuk
I changed the starter spring time usually it would last longer than this. Last month it would crank but really weak crank so I got a new battery. This is all after connecting a bad wire by the ecu and code 37 is still thereI would guess start went.
Might be a wire issue.
ty4stroke.com
This may help
Starter System Troubleshooting
With all the starting problems this my help save time and money. This link also has helpful info: Relay and fuse location diagram: http://www.ty4stroke.com/viewtopic.php?t=83992
ty4stroke.com
This may help
muffinboy
- Oct 10, 2024
- Kipnuk
Right, i wonder if that wire is reconnected isn't connected goodMight be a wire issue.
With all the starting problems this my help save time and money. This link also has helpful info: Relay and fuse location diagram: http://www.ty4stroke.com/viewtopic.php?t=83992ty4stroke.com
This may help
