garyr
- Nov 7, 2011
- Paradise, Nl..Canada
- 2010 Nytro XTX
I started up my Nytro ..preseason and checking everything out have noticed my left handwarmer isnt working...wondering if anyone else has this problem and what the fix could be ...thanks
Burnt out element. R&R with a new one....
garyr
- Nov 7, 2011
- 2010 Nytro XTX
do u have to rplace the whole grip to do this
smalltownpower
if your carefull you can get it off without wrecking it. heat it up really good with a heat gun or hair dryer to release the glue, put on a leather glove and slide it off...after you drill out the two rivets that hold it in. then take a utility or other sharp knife and scrape off the element. take emery cloth or very aggressive sand paper and get rid of all remaining foamy stuff left by the element. when putting the new element back on make sure your rivet holes are lined up, because taking the grip off after saying "oh crap" is almost impossible.
westbaycustoms
online i found the element for $33 and the grip for $8
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
I would get the replacement RSI kit from Yamaha and get the RSI gel grips also, by the time you get done dicking around with trying not to mess up the one grip you will have both done. The gel grips are sooooo much nicer then the stock ones too
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
XXX2222 I installed a set and know other people who have, Waaayy better than stock. Got mine from my yamaha dealersorenson1610 said:I would get the replacement RSI kit from Yamaha and get the RSI gel grips also, by the time you get done dicking around with trying not to mess up the one grip you will have both done. The gel grips are sooooo much nicer then the stock ones too![]()
Do you lose any heat using the rsi gel grips?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
bottlerocket said:Do you lose any heat using the rsi gel grips?
Dont know yet as i installed them this summer but i wouldnt think so. I have rocks yamaheater with boost so either way im covered! So much more comfortable though, well see how long they last......
Rock told me the rsi heaters are a lotter then then then oem.
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
Way hotter than oem. Sorenson- your going to be riding bare handed!!!!!
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
I just have my stock elements yet but hands were roasting at the end of the year with the yamaheater! I have thin gloves for this year
markowinnipeg
X2 get the RSI best move for toasty hands you can do
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
