2011 apex air box lid mod.
icebreaker
Southern wisconsin
2011 xtx
Here is my air lid mod I made that I am going to try on my 2011 with pc5 controller from Ulmer. I will let you know how much gain on top speed. It looks like this is a easy way to get cold air in the box because it is right under the hood vents and hidden that you cant see. Anybody try this?
Results yet? Do you have to use the pc5 controller?
Blue
air box lid and pc5
Yes, with the pc5 and this lid I am seeing 6mph gain on top end on hard pack. I like it also because it isn't very loud.
Riceburner said:
What is your top speed now?
:Rockon:
Speedo says 107on hard pack have had it read 116 on the lake with 2 inches of fresh powder snow. Conditions very a lot.
air box lid and pc5
Be aware that all of the air limitation into the engine has nothing to do with the intake capabilities of the air box on these machines. They will by stock design take in more air then the engine requires and are not restricting any air flow at all.. You can benefit from the colder air with the modification you have but virtually no increase in air flow into the engine. The primary restriction of air flow is the joint tubes that protrude into the air box. They are limited by design by the diameter and angle of flange. With no air box, test results are negligible. The increase you are seeing is probably a symptom of colder air entering the intake and increase fuel your adding with your power commander. The only way to get increase air flow in most cases is with a ram air type system or by removing the airbox and installing universal air filters(usually K&N) directly to the intake manifold. I DO NOT recommend this unless you can adjust fuel. Long story short. Your wasting the capabilities of your PC5 unless you start actually increasing the air flow into the engine.
Nine year old thread there fella.....
