2011+ Apex std long tracks kits ?
SicSixxx
PA, Saskatchewan
Canada
2011 Apex
2012 M1100 Turbo
I have 2011 Apex std w the 128" track. I want a longer track without sacrificing trade in. I tried too search but could not find any places that sell long track kits for my sled.
Does anyone know of a place? Sorry if this was covered, just couldnt find even with google. Everything was for pre 2011.
thank you
If you buy :
8HN-21917-00-00 PANEL, SUB FRAME 6 $48.60
8HN-1241A-00-00 HEAT EXCHANGER ASSY 4(or you could cut your pipes and lengthen them)
8HN-21978-00-00 PROTECTOR, FRAME $49.77(tunnel protector) x2
8HN-77541-00-00 BUMPER, REAR 1 $106.77
this will make the tunnel into the same/length as the xtx - i took these off to shorten my sled up on the asphalt last year when i ran the 128 asphalt track. There's the panel the snow flap rivets too that gets drilled out the the extension goes right where the rivet holes are and then rivet the rear panel back to the extension, then move the heat exchanger back, bolt new rear bumper on.
