grizzly101
- Jan 7, 2010
- saskatchewan
- 2011 apex xtx, 2010 rs vector gt, 2002 sx viper,1998 venture 600
has anyone pulled the skid on their apex xtx? i loosened the track lifted rear of sled off floor and undid the 4 bolts holding skid to frame. after much swearing got the skid out of tunnel but cannot get it out of track
heck i do it quite often. i usually take off the rear springs from their perch on the rails and compress the rear shock. some times need to tie down the shock if the nitrogen charge is good with a tie wrap. i slide it ahead a bit in the track and start working the wheels at the back out over the track drive nubs, some times with a pry bar some times without. the rear axle and wheels can be removed for more room if you need.
RobX-1
- Coldwater, OH
Kevin at Port Yamaha turned me on to this tool years back. Worth its weight in gold. Have used many of times. Makes not only changing your rear idler wheels a breeze but also helps in removing the skid as Maim mentioned.
http://shop.portyamaha.com/eshopprod_cat_10025-120606-191_product_2328669.Wheel_Changing_Tool.htm
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Taking the outside wheel off the rear axle is money. It really cuts down on the length of the skid when pulling to one side. Others mentioned some sort of skid mat slid under the skid to allow it to slide over the track. Not sure what it's called, but that would be good too! Sort of like these clear office chair mats
grizzly101
- Jan 7, 2010
- saskatchewan
tks guys for the input. will loosen springs and remove rear axle tonite. hopefully that will do it.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
I use an old broom handle/dowellKevin at Port Yamaha turned me on to this tool years back. Worth its weight in gold. Have used many of times. Makes not only changing your rear idler wheels a breeze but also helps in removing the skid as Maim mentioned.
RobX-1
- Coldwater, OH
This tool (a solid aluminum tube with a threaded end) actually screws into the rear axle shaft so that you can then whack it with a rubber mallet to push out the actual rear axle. Once out, unscrew and the tube holds everything in place. To re-insert rear axle, screw back on and reverse steps.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
i pull my skid without removing anything. Back the adjusters as far as they will go, lift the back of the sled up, use a strap by the rear upper idlers to hold the track up and walk it out from the front by using small broom handles between the track and the sliders to raise it over the track knobs. install it the same way.
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
so you install the rear into the track 1st? then wiggle in the front?
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Tried this trick last weekend with my XTX, worked mint, like, crazy easy by myself!!!
Blew my freak’n mind!!!
87gtNOS
- Nov 30, 2005
- Toronto
How high did you have the rear end lifted?
In the past, I have laid the sled over on it's left side and swung out the track and dropped in the skid and then slid it all under and then put the sled back on the skis...this is harder to do with the 144 though...
sgauthier
- Mar 5, 2009
- 2011 Apex XTX
correct, I install rear first as well when reinstalling the skid. I got tired of struggling with suspensions years ago so for $200 I bought a 400 lb electric ceiling hoist for my shop from princess auto just for suspension removal. I lift the back end up approx 3 to 3 1/2'. Enough to clear the front skid mount with it's metal protector loops by the drive sprockets. you might have to pull the track/suspension back a couple times during the install or removal to help slide it over. clear as mud?
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
We’ve got an electric hoist on a trolly hanging from one of the beams in the shop. You need to get the sled fairly high for the front arm to slide in under the running boards after the rear has been worked in. I agree, the 144 is a bit of a beast to wrestle with on your own.
