bman
Last ride of the season i started losing oil from the belly pan area ,oil level was dropping in the resovoir , dont see any hose leaks at bottom of res .havent checked the filter totally yet ,only leaks running, used a quart in about 60 miles, runs awesome,has about 12 ,000, havent done anything major, bogies etc and small bearing on the driven clutch side,any ideas on where to look ?
Check around your oil tank, they are known to leak at times. Check the seems and clean with contact cleaner.
