. That is, I was lifting one side at a time and adjusting the shock springs independently and that was making the springs way looser than by lifting the front completely off the ground and doing both sides. Yesterday I lifted it fully off the ground and the springs had no tension at all and there was about 1/2 -3/4" space/slop between the spring and nut. After adjusting with the front completely lifted the springs have more tension and the A-arms are not as flat now but it handles better with more control.
