SCM_Tuntaralek
- Nov 22, 2015
- Scammon Bay, Alaska
- 2012 Yamaha Venture Lite
Looking for some ideas on how to troubleshoot the reverse on my machine. We had a recent cold stretch and due to our location and limitations of storage I cover it up and keep it as out of the elements as possible. First thing I tried was applying heat to the reverse button in case of any ice or water build-up. No luck. Read on a forum that some people have tried letting it start with the throttle open. No luck. Next trick, was to start it and rock back and forth and then lift up the back. No luck. Last thing I tried was to check the fuses and they appeared fine.
Any ideas on what to try next?
Jason Harrell
- Aug 28, 2015
- Unalakleet, Alaska
- 2009 Arctic Cat F570, 2016 Yamaha Venture mp
You might look around some older posts in the venture lite/ multipurpose area...they covered some things to check...like making sure your belt is not too loose, or other things. I have a 2016 venture mp and even at 15 below recently, the reverse and forward was almost instantaneous. I just looked at some of the older posts and there is mention of making sure your rig is warmed up properly as well...I usually warm mine up for at least 5 min first thing in the morning. I already mentioned a belt change if you have a lot of miles on your current belt. Mooseman mentioned tightening some chain then backing off slightly...anyways , lots of info here
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
You don't mention what the symptoms are exactly. What happens when you push the button?
SCM_Tuntaralek
- Nov 22, 2015
Symptoms: The Drive Light (green one) has always typically been on following start-up and while moving forward, but it has not been illuminated since the reverse has stopped functioning. Both the reset and mode functions appear to be working as well as the display and gauges. When the reverse is pressed, the machine does not respond at all: keeps running and stays in forward gear with no response at all. That's why I was thinking maybe a fuse or something.You don't mention what the symptoms are exactly. What happens when you push the button?
SCM_Tuntaralek
- Nov 22, 2015
Thank you. I will have a look tomorrow.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Sounds like the fuse or something disconnected. If the fuse blew, there must be a reason. The reverse system is independent of the gauge pod itself. Download the repair manual and check the diagrams for connectors and circuits.
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
- 1997 vmax 600 sx, 99 venture 600, 2004 vk 540, 2006 Yamaha vk pro, 2009 venture multi purpose and 2006 venture 500 xl current ride 15 rs viking pro
there is a bank of relays in behind your battery and I do believe there is a relay for reverse and they are prone to freezing and sticking. Use a hairdryer on the relays to thaw them out. If the reverse works you should replace the relay due to moisture content or you could dry it out and use a silicone sealer that would be used to seal plug wires on a car or truck!
SCM_Tuntaralek
- Nov 22, 2015
Thanks, I'll give that a shot tomorrow. The other symptom I forgot to mention is that the yellow warning light is flashing (usually this is what happens when the fuel is running less than a bar or 2) constantly, even with a full tank.
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
If you have a flashing yellow light, you have a warning and in your dash or pod there should be a two digit number flashing and at the begining of the venture lite/ multi section, there is a section with a list of fault codes this will point you in the right direction!
SCM_Tuntaralek
- Nov 22, 2015
Checked the relays (they are really hard to get to behind the battery) and hairdryered them for a while...the yellow warning just flashes the fuel tank, but there is no code like I've seen in the past. I'm wondering if you can count the flashes to figure out another code? Been checking and re-checking multiple things
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
That would mean you are either low on fuel or the fuel level sender is either faulty or disconnected. Forgot to plug it in once and it did that.
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
I'm a little confused, If you are talking about the amber triangle light that will come on with low fuel or if you have a fault either or! If no code is appearing, It's a good chance it's not electrical, code 88 is for reverse problem according to the post in the list of fault codes.
- 18K
