greggie42
thanks for all your advice guys, i bit the bullet and scraped the wife's phazer and sure enough the plugs were killed from flooding, i have given her a lesson on starting it in the future. its working fine now but i get OP-LO flash up for just a second and then go away. never saw it do that before. oil level is fine. anything to worry about?
Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
If it was flooded bad I would change the oil. When the fuel/air mixture enters the cylinder on a non running motor it can push the fuel past the piston rings and into the cylinder. Pull the oil level stick and smell for fuel contamination. If you smell fuel change the oil.
greggie42
thanks, thats a good point. i will check that
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
My Phazer flooded again this morning in our -35 degree weather, pulled the seat, unplugged the fuel pump, cranked the engine till it started to fire, then plugged in the fuel pump and it started right up.
- 19K
