sparks49
My wife's 2014 Vector darts like crazy. I've made multiple adjustments to the rear suspension, adjusted the front springs, set the toe-in to 0 degrees, changed to front wear bars to 4" carbides on the inside and hard bars on the outside, all to no avail. My next thought was to go back to a single keel ski with Dooley's. We don't run picks on the sled. My question is, will this help solve the darting problem and what factory skis fit this sled? I have a couple of 2006 Vectors and was thinking of trying a swap, but don't know if it'll work. Any thoughts out there? Thanks.
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
SnowTrackers with toe at 0. 100% fixed!
Fazed
- Mar 18, 2018
- Nova Scotia
- 2013 Vector LTX
X2 on the Snow Trackers. On that year of ski/sled the semi aggressives are reported to work best.
sparks49
Thanks guy's, that's the info I was looking for. Really appreciate it.
Banjo Man
- Nov 5, 2012
- Lake Barrington Il.
- 06 Vector GT. 15 Vector Ltx . 14 Vector Ltx
I have a 2015 LTX and put on single keel skis from an 06 with semi aggressive snowtrackers and works really well. I just never liked the tuners.
all the old yamaha single keel skis bolt up. i am running 09 mtx skis on both the 11 and 16 apex xtx.
TRUE BLUE SINCE 1980
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
Cheep fix may be shimming the ski rubber at the back.
This will lift the ski tips up. We also weld and bolt a steel
"Smasher Plate" before the wear rod.
On the single keel ski ,works for us
