Interesting. It's very rare for the exhaust valves to lose clearance. Usually intakes are the culprits.So had a Yamaha Tech take a look at the machine; good news is he found the problem. Bad news is, its a huge job.
Looks like the exhaust valves are all out of adjustment.
Flat rate calls for 14 Hours. The entire top half of the machine as well as the cross member have t be removed to access the valve cover.
So far it looks like the dealer (SM Sport) is going to help me out since thanks to the lockdown I can't take it to QC and they are going to work with my local dealer. Just trying to haggle out a deal on what they want to pay verses what the local shop wants to charge.
JasonR
- Dec 28, 2020
- Kawartha Lakes
- 2016 Vector XTX LE 1.75
He said similar. Also said he can only remember a handful of them ever needing an adjustment at all.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
How many miles on your 16 vector?
JasonR
- Dec 28, 2020
- Kawartha Lakes
16,600 KM
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
So that's just over 10,000 miles.
You would think Yamaha would cover this under warranty.
I also have a 16 with only about 4500 miles on it.
So far so good.
So far so good.
JasonR
- Dec 28, 2020
- Kawartha Lakes
I think warranty is 2 years and the machine is 5 years old so would be a bit much to expect.
I'm a new owner to this machine. The tech tells me that this has probably been a worsening problem for quite some time so maybe had they gotten it looked at sooner it would have been done under factory warranty.
As it is, it will hopefully be covered by the used vehicle warranty.
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
This bothers me. Maybe I am overreacting. But the exhaust valves are stretching due to heat. I felt this more related to Vipers. Than rear exhaust Sleds. The old school diagnosis for this is to hold a piece of Cardstock paper. To hold it to the exhaust pipe. When the piston goes down on the intake stroke if the exhaust valve is open or burned. It will suck the paper to the tailpipe. Because the leak creates a Vacuum. I have experienced this myself. Lol it was on a ford Truck.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
So did the tech remove the valve cover and measure the valve clearance or is this an assumption on his part?
JasonR
- Dec 28, 2020
- Kawartha Lakes
He was able to open the cover enough to check the clearances.
Removing it is a huge job as there is apparently a sadist in charge of design over at Yamaha!
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
I'd ask to inspect it with the tech. I agree with grizz and question his diagnosis.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
The valve cover is not that hard to remove but if the valves need adjusted the cams need to be lifted which means the timing chain would need to be removed then reset. To do that the rear engine mount would need to be removed so the engine could be rocked forward to gain access to the chain tensioner.
I find it hard to believe that the valve lash clearance was measured correctly or measured at all. You may want to have the reluctor ring on the stub shaft checked to see if it slipped and if the valve cover was lifted or removed the cam/crank timing marks should have been checked to make sure the chain didn't skip.
JasonR
- Dec 28, 2020
- Kawartha Lakes
I was there to see him check. 5 out of 6 valves require adjustment.
He said the problem with this job is the exhaust has to be removed since it is rear exit. Which requires tank and seat to be removed.
Spec is minimum 0.008 thousandths, but imo, unless there is less than 0.006, it isn't the trouble.
JasonR
- Dec 28, 2020
- Kawartha Lakes
UPDATE: So got the sled back today. Tech left it parked in unheated shed over night so was good and cold. Started up first fine as usual. Then idled perfectly, no stalls, surges or sputters. Took it for a quick blast up and down the lake did some hard brake applications and couldn't get it to stall...
Best part... The selling dealer has agreed to cover the cost for me, which I think is pretty good of them since they could have said no as the warrantee is for their shop only.
So shout out to SM Sport in QC.
- 9K
