Wundo
- Oct 21, 2018
- 2016 Yamaha phazer X-TX
Hey I’m new to this but I have a 2016 phazer x-tx and I just bought a MBRP exahaust for it other wise everything is stock and I was wonder what else I should do any thoghts!?! Please list mods for phazer!!
front bumper (if you canfind one), float plate, hid head lamps from rockmeister and better skis for off trail will make it an awsome season for you.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Out of EVERYTHING I've done to my Phazer, I'd start with a good full protection skidplate (I have the Skinz) and upper balljoint mod. I did my balljoint mod a bit different, I removed material from the balljoint seat on A-arm instead of cutting down the balljoint so when the joint needs replacing I don't need to have it machined. If you play off-trail much I'd ditch the tuner ski as they flat out suck in powder, the Phazer/Nytro MTX ski works well.
Wundo
- Oct 21, 2018
Thank you! I was looking at the skid plates from skinz but the years of the sleds seem to max out at 2010 should that matter considering mine is 2016!?Out of EVERYTHING I've done to my Phazer, I'd start with a good full protection skidplate (I have the Skinz) and upper balljoint mod. I did my balljoint mod a bit different, I removed material from the balljoint seat on A-arm instead of cutting down the balljoint so when the joint needs replacing I don't need to have it machined. If you play off-trail much I'd ditch the tuner ski as they flat out suck in powder, the Phazer/Nytro MTX ski works well.
Wundo
- Oct 21, 2018
Thank u I appreciate it!front bumper (if you canfind one), float plate, hid head lamps from rockmeister and better skis for off trail will make it an awsome season for you.
Wundo
- Oct 21, 2018
Never mind about the 2010 thing I went back on the website and mis read but thank u I just ordered the front bumper!Out of EVERYTHING I've done to my Phazer, I'd start with a good full protection skidplate (I have the Skinz) and upper balljoint mod. I did my balljoint mod a bit different, I removed material from the balljoint seat on A-arm instead of cutting down the balljoint so when the joint needs replacing I don't need to have it machined. If you play off-trail much I'd ditch the tuner ski as they flat out suck in powder, the Phazer/Nytro MTX ski works well.
I liked ULmER’s clutching on Phazer. Worked well right out of box.
Oh and Axis rear shock transformed mine.
Being a xtx the Mountain Tech boards really are transforming too. Love mine
