john928
- Feb 2, 2024
- NJ
- 2017 Thundercat
Yes, it’s now $155 less than when I purchased in March. County Cat is refunding me the difference since the new part number is less expensive. Country Cat has been a pleasure to deal with and I do recommend them if you need parts.Nice price on Country Cat
Anyone else that would be interested in harnesses I have one ready to ship. If I there are more requests I will have to order more ends and will take about 2 weeks to get them built and shipped.
Farmer 73
- Feb 20, 2015
- 2010 NYTRO RTX SE, 2012 VECTOR, 2001 SXR 600, 2001 PHAZER, 2000 PHAZER, 1983 ENTICER EXCELL III
Tom, would this work on a 22 Viper and or do I need one on a 22 Viper GT?
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I thought I read somewhere that the 2022+ Sidewinders had provisions on the factory harness for EPS and that your harnesses aren't needed. Then I re-read this thread and see on post #50 that you state that you are unsure if it is needed for the newer ones. Does anyone know if the harnesses that Mr. Sled builds are needed for a 2023 Sidewinder LTX SE?
If it has it there would be 2 plugs that would be close to the steering post. It might be taped up or zip tied to the main harness. On a side note even if you have my harness it will send power to the unit and tie into the inspection port by the reverse and basically pie pass the main harness.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Right, I just thought I read there for his 2023, he shouldn't need your harnesses since they likely all come from the factory with the same harness regardless of whether or not they have EPS.If it has it there would be 2 plugs that would be close to the steering post. It might be taped up or zip tied to the main harness. On a side note even if you have my harness it will send power to the unit and tie into the inspection port by the reverse and basically pie pass the main harness.
I had heard that too. Would be nice to see a picture of someone who has that.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Its there, you can even see it in the wiring diagram. Connector 16 is the EPS power (EPS fuse), and Connector 51 is EPS signal (basically tapped into canbus + taillight power)
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Thanks!!Its there, you can even see it in the wiring diagram. Connector 16 is the EPS power (EPS fuse), and Connector 51 is EPS signal (basically tapped into canbus + taillight power)
DTJ
- Mar 31, 2016
- Brainerd, MN
- 2023 Yamaha Sidewinder XTX
2017 Yamaha Sidewinder BTX
I did my 23' a couple months ago. The harness is zip tied to the cross bar from the factory. Both plugs have a blank plugged into them. Just remove the blanks and it plugs right into the motor.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
How long did the install take you?I did my 23' a couple months ago. The harness is zip tied to the cross bar from the factory. Both plugs have a blank plugged into them. Just remove the blanks and it plugs right into the motor.
DTJ
- Mar 31, 2016
- Brainerd, MN
I think it was all of 4 or 5 hours.
I will have 4 more harness kits ready in the next few weeks if anyone is interested.
