2017 Sidewinder EPS Install Video and Info
MrSled
Site Admin/CEO
Staff member
Schofield, WI
Website
www.totallyamaha.com
2020 Sidewinder SRX
Here is the Video of the install:
Step by Step information how to install EPS (Electronic Power Steering) on your Yamaha Sidewinder 2017-current that don't originally have EPS.
Step by Step information how to install EPS (Electronic Power Steering) on your Yamaha Sidewinder 2022-current that don't originally have EPS and had harness and holes prepped into the bulkhead by factory.
There are 2 PDF's (PNG) shown, one is the info needed for you to build your own harness and the other is a the final parts lists needed with Yamaha part numbers and Cat part numbers for ordering all show at retail pricing. Most dealers and websites will give 10-15% off. If anyone is interested in my harness for quick plug and play installation or for me to do the installation for you please message me. Remember installing these in a timely matter is all based on availability of parts.
Update 11/5/24: After further review on our new 2025 EPS Sidewinder, you could reduce the size if the main harness wire to 12ga for main power and ground as well as change the trigger power wire to 18GA. I have updated the attachments.
If you want to split your power source there is a 2 outlet splitter #1639-623 and 3 outlet splitter #1639-624
Update 3/6/2025
If you are moving the CDI bracket to clear the stock harness per my instructions be sure to order yourself black rivets or you can get some from Amazon.
Also do not over-tighten the 2 - 10mm nuts on the upper steering shaft by the handle bars, this needs to be just touching not too snug or the EPS will not feel like its working. It cant overcome the resistance if over-tight. This also should be greased.
Update 11/2/2025
Two Gold Stars!! Awesome work
Now if only there was a way to retrofit Apex/Vector power steering motors. I have a pile of them sitting around.
I have never seen one, what do they look like. As simple as the EPS is, I am sure that it can be done as long as their is room.
Nicely done Tom. Pretty much exactly how my install went. I did not move the plate for the brains on the right side though.
Great!! I was worried about wires rubbing. Could always just zip tie a hose on that bracket edge too.
I should look at that a little closer just to be sure. Thanks!
Are you saying you are building harnesses to sell?
EXCELLENT video!!!! Kudos to your camera person. That is the way these DIY videos should be done.
Another reason why this site is the best.
I have enough material to build and sell a few.
Amazing!!! Thanks you!!
Thank you guys. Spread the word. We could use some more traffic, thought this might help
I would be interested in the harness you built. You mentioned you have a few that may be available?
Thanks!
