sport20
- Jan 9, 2005
Hi
2018 vk540
Replaced
Kill switch
Key ignition
Solenoid.
If I cross the solenoid motor will turn over but no spark.
Try key and motor will not turn over.
Anyone got any ideas what's going on
2018 vk540
Replaced
Kill switch
Key ignition
Solenoid.
unplug the ignition and see if you have spark. this is based on the vk540 through to vk540III that i have delt with. fuses all good?
sport20
- Jan 9, 2005
sport20
- Jan 9, 2005
Fuses all good. Tried pull cord with ignition unplugged still no spark. She got 3 relays up front beside ecm and voltage regulator. Only thing that would stop her from turning over on key would be kill switch,solenoid or ignition I think. Unless there's something I'm missing
try swapping the relays. then try with kill switch un plugged. after this, i would be testing the pick up coil and checking the wiring harness for rub throughs.
hydraulic yam
- Nov 12, 2025
- Mt Albert, Ont
- 2013 Apex XTX
93 Yamaha VKII, assorted fluid drive Yamahas
Curious .. circumstances ?? did it work fine day before ?, shut off and didn't restart a few
minutes later . ? 1st run of season ? I noticed these new ones are way more High tech
than my 93...
Any chance it was boosted or boosted someone else ?
I'm going to look at your other posts
Ron
than my 93...
Ron
sport20
- Jan 9, 2005
Hi
Forgot to mention we put new computer/cdi on it also. Anyway we unhooked battery and looked around. Put battery back on and it worked great. Not sure if battery had to be unhooked to reset computer. It’s a mystery. lol
