And 9 tooth 3 inch pitch drivers may cause the track to not fit.Just adjust gearing. There is no 141 track with a 2.86 pitch to my knowledge.
As already stated just gear the sled up a bit.
My 2019 X-TX came with a 141 x 1.75 track, 21/41 gears, and 8 x 3" drivers and had no trouble easily breaking 100+++ mph
- 141 SW X-TX with 8 x 3" drivers and 21/41 gears tops out @ 103mph at a 1:1 shift ratio, 6% overdrive will give you 110mph[8800 rpm]
- 137" SW with 9 X 2.86" drivers and the same 21/41 gears tops out 110mph at a 1:1 ratio, 6% overdrive will give you 117mph[8800 rpm]
If you just change your x-tx gears to 22/41 with the same chain, 1:1 = 108mph and overdrive = 115mph[8800 rpm]....You probably need a new top gear anyway if the sled has any miles on it.
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
- 2018 Sidewinder xtx
16 viper xtx se SOLD
08 nytro rtx SOLD
- Kirkland Lake
Yes needs a new gear already! Was trying to find 9 tooth with a 3”pitch. Will play with gearing I guess.As already stated just gear the sled up a bit.
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
If you want it to go faster pour the HP to it, Turbo Dynamics, Hurricane or Precision can deliver a lot of power and top end speed.
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
08 nytro rtx SOLD
- Kirkland Lake
Turbo Dynamic’s multi flash already. Usually leave it on 290 map.If you want it to go faster pour the HP to it, Turbo Dynamics, Hurricane or Precision can deliver a lot of power and top end speed.
