thunderbolt
I'm just wondering if anybody has measured the width of the new SRX , from outside of the skis , I'm picking mine up next week and just wondering if its going to fit in the back of my ram 1500 between the wheel wells
RAMSOMAIR
It will fit fine
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I have ramped mine into my RAM(6'-4" Box) many times when searching for snow...SRX should be same as my RTX.
Dan
Dan
ApexXTX/Viper
- May 5, 2014
- 2019 SRX, 2018 Viper LTX
I believe you can adjust ski stance by swapping the collars at the base of the spindles where they bolt to the skis on the 2020's (with new front end) same as the 2019's. You're probably 50 inches between wheel wells on your Dodge(slightly less with bedliner) so should fit easily with skis mounted in either position.
Crazy Canuk
I can confirm that this is the same for 2020.
