Bigboyben89
- Jan 3, 2026
- Ottawa ontario
- 2020 viper ltx gt
So I've had my viper since November and I've put 1100km on it since. I'm having a problem where I'm suspecting my secondary isn't shifting good even after a cleaning. At around 107 kph if I'm doing a wide open pull it hits limiter and when i let off a little rpms drop 1000 and i can get back on it and it keeps pulling. I'm suspecting my secondary is binding or something but not sure. My spring wrap is 6-1 if that matters any info is appreciated thanks
What's the total miles on it? I suspect the more likely problem is the clutch weights have a notch in them at about the halfway mark.
Bigboyben89
- Jan 3, 2026
- Ottawa ontario
- 2020 viper ltx gt
11k km so 7k miles I thinkWhat's the total miles on it? I suspect the more likely problem is the clutch weights have a notch in them at about the halfway mark.
Bigboyben89
- Jan 3, 2026
- Ottawa ontario
- 2020 viper ltx gt
Well you were bang on thanks allotWhat's the total miles on it? I suspect the more likely problem is the clutch weights have a notch in them at about the halfway mark.
