jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The stingray spring is a straight/single 160 ???
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Yes.The stingray spring is a straight/single 160 ???
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
My center shock is the standard hpg shock.
I have run stock 110 lb spring.
Stingray 160 lb spring .
Cat 160/260 lb spring.
So far liking the Cat 160/260 spring the best.
Would like to try the hy gear dual rate center spring with the adjustable crossover. Hygear says their set up is simular in rates to the cat spring I listed.
Some others have reported the Raptor spring they like.
220 lb rider
220 lb rider
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I have heard of that Raptor triple-rate spring and tried to get them to tell me the spring rates, but they wouldn't give up that information. Because of that, I have not ordered one yet. I need to know spring rates to determine if it will be better or worse than what I have.My center shock is the standard hpg shock.
220 lb rider
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
This is the spring I ran for 10k miles. I had a link in post above?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I miss posted earlier. The triple rate raptor is what I like and ran in the SE With NON CLICKER shock.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Myself and a couple guys have tried the Bill Mohr spring and prefer the Cat progressive spring hands down.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
From what I have read on this site with the help of the search tool, the Stingray spring will work on my 17 LE Center shock with reservoir. Some state that this spring works without wearing the shock body, or hitting the reservoir. But the Cat dual rate spring will wear the shock body! Once my shock is back from it’s refresh, I shall certainly compare it against the stock dual springs and try a bit of R&D before using it!
Thanks for all the info!
Turboflash
- Mar 18, 2019
- Southern MN
What are the specific differences that cause you to prefer the Cat spring?Myself and a couple guys have tried the Bill Mohr spring and prefer the Cat progressive spring hands down.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Rides better, takes the big bumps betterWhat are the specific differences that cause you to prefer the Cat spring?
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
What shock are you using it with, reservoir?Rides better, takes the big bumps better
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
No reservoir
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Same here.Rides better, takes the big bumps better
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I tried the Raptor straight rate spring on my 2017 RTX, I too thought it ruined the ride and went back to the factory spring. That said I don't hammer the rough stuff like I used to.
Sold the Raptor spring to a fellow with a 2020 ZR800, he weighs @350 lbs, and is short,. and found that spring really helped his handling/ride issues .
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
What are stock spring rates compared to the 160/260 rates? On a 17 LTX LE.
