Rossv123
- Dec 15, 2020
- Michigan
- 2018 Thundercat
I have a 2025 SRX with about 3300 miles tuned on max 17 with the normal supporting mods. I broke a secondary spring earlier in the year and the same day the sled starting bogging and falling on its face past 3/4 throttle. I drained the fuel cleaned the fuel socks and put a TP black orange spring in and it seemed to run fine for about 200 miles. Now the sled will only rev to 8550 it will then flash the knock light and when you come to a stop after a pull it wants to die. I did a new fuel pump, injectors, map sensor, spark plugs. Boost is around 16.9 at 84-8500 RPM. Any Ideas? Thanks
High flow pump? Stock pump probably won't suffice.
The MAP sensor should be the upgraded 4 bar?
Is the secondary or primary clutch sticking or binding? If the clutches are not releasing or returning to their resting position it could cause the sled to stall at idle. Dont know how that would cause knock light though.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Sounds like clutching to me. Knock could be due to low rpm load.
Rossv123
- Dec 15, 2020
- Michigan
- 2018 Thundercat
Yes it is a high flow pump. And it is a 3 bar although i swapped it out and had the same resultsHigh flow pump? Stock pump probably won't suffice.
Rossv123
- Dec 15, 2020
- Michigan
- 2018 Thundercat
What should I be looking for as far as clutching goes? It has new primary rollers (stock roller) new secondary (TP) a straight 35 tp helix and a dalton BO spring.Sounds like clutching to me. Knock could be due to low rpm load.
Rossv123
- Dec 15, 2020
- Michigan
- 2018 Thundercat
New secondary rollers is what I meant by new secondaryWhat should I be looking for as far as clutching goes? It has new primary rollers (stock roller) new secondary (TP) a straight 35 tp helix and a dalton BO spring.
Put a fuel pressure guage on that you can monitor as you ride.
- 23K
- 7K
