done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
did you see this one?Dan where did you find this calculator
http://www.turboaddictionparts.com/catalog/snowmobilecalculator.html
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Hi GuysIf you have heavy steering, which is probly the number one complaint on here in stock form, you will be robbing speed up top.
There are lots of variation in speeds reported. I have about 450 miles on my stock LTX-SE across the lake with some light snow I am maxed at 103 @ 8250 rpm temp in the 30's. My belt and clutches look good and no flat spots on secondary rollers. Just curious as to how people are reaching 120 stock.........................
roadking
- Jan 8, 2017
- minnesota
- Yamaha sidewinder
My top speed so far is 120 bone stock no flat spots on my rollers 1100 miles still on original belt ran with 6 Polaris 800's and one 800 cat, not even close. Still looking for that 850 Skidoo. My last sled was a 2012 Apex that was even with the fastest 800 in our bunch!
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
That's impressive. Which model? Seems to me I've heard higher speeds on the SE models.My top speed so far is 120 bone stock no flat spots on my rollers 1100 miles still on original belt ran with 6 Polaris 800's and one 800 cat, not even close. Still looking for that 850 Skidoo. My last sled was a 2012 Apex that was even with the fastest 800 in our bunch!
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I also have 650 miles on my LTX LE , had to replace the belt , as I drove it with the parking brake on , and created a flat spot !I have been up to 129 gps on the stock gears. This on plowed ice. That is really the absolute end of stock gearing. So clutches were shifting completely out. And still original belt. About 650 miles now...and although I don't go beating on it looking to try and blow a belt...I don't take it easy either.
Dummy me !
- Dec 6, 2016
- saegertown pa
after looking at many spec sheets and finding no difference, if it is certain models reaching speed, could it be the ecu flashed a bit differently?That's impressive. Which model? Seems to me I've heard higher speeds on the SE models.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Very similar to mine. 8400 rpm. 106 max every time. 430 miles. No belt or roller issues yet. Dealer wrapped secondary to 70 and shimmed clutch at first service. Haven't been able to ride again yet.Hi Guys
krm
- Apr 22, 2016
- ny
studs,or no studs ?My top speed so far is 120 bone stock no flat spots on my rollers 1100 miles still on original belt ran with 6 Polaris 800's and one 800 cat, not even close. Still looking for that 850 Skidoo. My last sled was a 2012 Apex that was even with the fastest 800 in our bunch!
thunderbolt
thanks , I hadn't read that topic thanks again
roadking
- Jan 8, 2017
- minnesota
- Yamaha sidewinder
I have studs and it's the LTX SE
DIwarrior
- Oct 22, 2003
- Drummond Island MI
- 2025 SRX LE #473
2025 SW XTX LE
2025 SW LTX GT
2001 SRX
1968 Ski-Doo
- Drummond Island, MI
- Nope
LTX-LE, 1,465 miles, Ice Attack XL track. Max speed has been 109 GPS/114 Speedo several times. Top RPM 8900. Blew one belt so far while cruising at 85-90. Snapped it, not shredded, clutch and driven warm to the touch, rollers looked good, 1,029 miles. Lovin it so far, coming off of 08 Apex LTX.
Winderman69
- Dec 31, 2016
- New york
- 18' sidewinder RTX 50th anniversary
Just got back from st.raymond Canada, 106 on speedo on my ltx.. Friends are all saying 114-116 I'm not even close .. Doesn't even feel like there's anything left.. 755 miles original belt ... Any thoughts? Also ran out of gas 83 miles( my gas gauge isn't working either ) Yamaha has no answer for that either
Snowaddict
- Feb 28, 2005
- Menasha, WI
- mstahl88
Are your friends running LTX-LEs as well? Are you all stock? I personally think the SEs are faster on top from the reports here. I wouldn't be too concerned as it seems what you are at currently and mileage (as in break in) is probably comparable to other LTX-LEs. I'm hoping for more myself after the 1000 mile mark. What's your Rpms?Just got back from st.raymond Canada, 106 on speedo on my ltx.. Friends are all saying 114-116 I'm not even close .. Doesn't even feel like there's anything left.. 755 miles original belt ... Any thoughts? Also ran out of gas 83 miles( my gas gauge isn't working either ) Yamaha has no answer for that either
The fuel mileage is definitely an issue, though. I have gotten 14 mpg and at least 100 miles on a tank (probably 110 even too, but wasn't paying attention. )
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
My SE stock did 118mph gps (121 speedo) on snow. Since tune it's obviously much faster...but I did put 116 miles on a tank...fast trail riding last week. Took 32.2 liters to fill. Something up with yours for sure
SBT
- Feb 22, 2017
- Arnprior ON
- 2018 850 Renegade X
Friend and I took a Sidewinder LTX-SE 137 for a test ride from the local dealer. Buddy brought it up to 115 mph on speedo in wet snow conditions and over not that long of distance. I seen 110 and shut it down. Hardest pulling trail sled I've been on.
- 9K
