Excel
- Nov 17, 2015
- Manitoba
- Nytro
Hi, looking for help diagnosing a problem with a 240 turbo kit. I installed the kit myself except for the headshim, which was done by a local mechanic. When I first went to start the sled it would not start. It would crank fine. I found that I can get it to start if I hold the throttle wide open and can keep it running with the throttle partially held, It will not idle.
Any input would be greatly appreciated
I have disconnected the fuel to the secondary injectors as per MCXpress instructions but it made no difference.
I have checked and double checked all connections.
Sounds like the cam timing might be off.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Agreed you should check cam timing
Excel
- Nov 17, 2015
- Manitoba
- Nytro
Thanks, I had the head shim and head studs done by someone else. I aligned the marks on the stator and took the valve cover off to inspect. Timing definitely off. So out the engine comes.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
you dont have to take the engine out to retime the motor. can be done inside the sled if you so choose. Just have to undo the rear engine mount and tilt the motor forward so you can access the tensioner
Excel
- Nov 17, 2015
- Manitoba
- Nytro
I'm getting good at it now. I pulled it out and setup the timing to exactly what my shop manual said and its still off. After some searching I found people saying that the stator should be set at the II mark and not the I mark like the manual said. Can anybody confirm this?
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
With the head shim isnt there a different procedure for timing the cams? I thought you had to slot the cam gears because the shim is raising the head.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
Go to mcx.se/manualer and read how to install the CAM.
aaronbellmx355
- Mar 13, 2013
- vernon ny
- 2009 Nytro RTX push turbo
2014 Viper XTX
ditch the shim and do low comp pistons
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
fwiw when mine would not idle I had the idle air tube blocked off still I put tape over it when i was doing the work in the engine bay. was same symtoms as you describe.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yes II mark is for cam timing
