idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
Both the 240 and 270 tunes are stock muffler tunes. Hurricane SM multimap is 225, 240, 270. PM multimap is 240, 270, 300. If you go with a PM you need the 300 tune. Make sure you get the right tune for your exhaust (SM or PM), they are different.So....no change to clutch weight? Your stock muffler doesn't get extremely hot? How many miles on this set-up? Ty...
Just debating the 240hp & 270hp range. 240 is seemingly a simple tune. The 270hp may or may not, incur significantly more dollars past the cost of the tune. Muffler, bov, etc.
Then there's the bundle tune and flasher debacle....lol.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
MY TURN HERE:
Since this about Hurricane & cost, i'll keep to those variables.
In the trails, i thought the 240 SS SM was best compared to the 270.
No need for Muffler or crazy clutching.
You can keep the stock belt since it's only $70
Dalton weights, BOV & a rear spring.........................all done
YES there are some more benefits of extra stuff, but when does the $$$$ outweigh the HP? YOUR call
I think the 270 needs more clutch work, better gas & yes IMO a Muffler. It does get hot at 270. I felt it on my boot.
Using a different belt not only costs more, but then needs to be dialed in. That costs more $$$ if you don't hit it on first try.
More power needs more studs..............'MO Money
P.S: There are many comparable clutch components out there, i only said Daltons cuz that's what i had
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
I’m not sure others would agree but I run the 240/270/300 pm tune.240 tune....$550?!?!
I hear some can ease the RPM 's with an xs825 belt. Some have said yes, some say you'll still need additional weight to correct.
270 tune (stock muffler) is $100 more, whatever?!?!
This seemingly adds Appx $2,000 in additional product. Stock muffler gets very hot. Probably will need a better flowing muffler. Bov becomes questionable and most likely need replacement. Dalton adjustable weights. May as well bundle it. Dash flash protocol. As well as xs825 belt, etc. Brings that up to $2500 +
Now I'm just passing the time during the off season...
If that is correct, the $1,800 for 30hp doesn't seem to make a whole lot of sense. Considering the first 40hp cost a 1/3 of that.
I think I'm being quite realistic, no?!?!
I run 270 most of the time
The odd time it inadvertently gets switch to the 240 I think my sled is broken it’s that different
270 is a lot of fun corner to corner if you can afford it you will not be sorry
The 300 borders on insane
This is for aggressive trail riding
As someone said it’s also highly addictive
If you just do a 240 your likely going to go to the next level cuz you know it’s there
Good luck deciding
SledFreak
- Feb 7, 2005
- Ontario. Canada
IMO, the 240SS SM tune is a really nice mid and pulls good up top. However, the SM tune loses throttle response out of the hole or when going 10-15mph and a quick stab of the throttle over stock. The 270 PM brings that back to a little better then stock and then brings even more mid, top end and better on fuel. The muffler is really the big cost. Find a used muffler.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
New.....a muffler, bov, 3 or 4 bar map is under $1,000. Just trying to find ways to justify it.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Boost is an addiction... Thats your justification...
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Don't tell your wife......
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Stock weights, XS825 belt, Yamaha blu/brn/blu primary spring, stock seconday spring wrapped at 60, TS BOV.So....no change to clutch weight? Your stock muffler doesn't get extremely hot? How many miles on this set-up?
The stock muffler gets hot if I make a really long pull, but it has not melted anything. For trail riding it is fine IMO.
Doc Harley
- Oct 17, 2016
- Here & there
I've been looking at the max16 for a bit. It's almost too good to be true. It flys under the radar & the expense of a full tilt bogie.
Thank you for sharing.....
One last....when cruising around (98% of the time) I'm getting 15mpg religiously.
Did fuel consumption increase or decrease for you?
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Slight decrease in most conditions. I see 14.5 mpg when cruising on a cold day. My dad has a stock machine and last season I ran out of gas at 128 miles. He made it 5 miles further than I did.I've been looking at the max16 for a bit. It's almost too good to be true. It flys under the radar & the expense of a full tilt bogie.
I get my worst mileage on warm days. I've seen as low a 11 when riding in 40 degree weather.
I have about 3,500 miles on this setup. I blew my first XS825 up at 3,000 miles.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The hurricane 270 tune claims faster spooling and all it requires is a BOV and clutch arms, it also claims better than stock mileage. The upgrade from there is 285 HP which requires the header and 93 octane. Still with the stock muffler. Even it it makes less than 270, its a pretty good deal. Wondering why this isn't more popular or is everyone running TD?
240 – Requires: Clutch Arms
270 – Requires: Clutch Arms – BOV
285 – Requires: Header – Clutch Arms – BOV – 3 or 4 Bar Map sensor – 93 octane ( SM only )
290 – Requires: Clutch Arms – BOV – Stock 2 bar Map Sensor – 93 octane ( PM only )
300 – Requires: Clutch Arms – BOV – 3 or 4 bar Map Sensor – 93 octane ( PM only )
Bundle – Requires: Cluster Flash – Clutch Arms – BOV – 3 or 4 bar Map Sensor
SM = Stock Muffler PM = Performance Muffler
225 – entry level flash, no modifications required ( SM only )240 – Requires: Clutch Arms
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
How did 240ss feel compared to your Powertrail tune?MY TURN HERE:
stgdz
- Mar 27, 2021
- Buffalo MN
Just get the pm bundle, ss upgrade, and supporting mods and call it a day.
You will end up there eventually so just buy once cry once.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
That is about the best way to put it and good adviceJust get the pm bundle, ss upgrade, and supporting mods and call it a day.
Doc Harley
- Oct 17, 2016
- Here & there
I completely understand. I've limited my riding to one or maybe two trips per year.Just get the pm bundle, ss upgrade, and supporting mods and call it a day.
So, frankly, I can't justify all additional expenses.
Looks like it's just a tune, belt & a bov would be the extent of it.
So I'm trying to make sure I maximize this on the first shot.
- 6K
- 6K
