my accesory fuse for heated shield seems to blow kind of easy.i cant find these 3 amp mini fuses anywhere(radio shack,auto part stores,or even e-bay)i hate to have to drive an hour and a half to dealer just for fuses!~
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I put the 4 amp spare in mine...works fine.
I also hardwire my elec shield into this circuit,which means i DO NOT use a 12volt cigg lighter type plug in for elec shield....everyone I know who uses these blows fuses alot.
Dan
Dan
Thewhitedogg
Bought mine at walmart. I have blown the 3 amp several times with the heated shield so I just started using a 5 amp. No problems since
Coondog2707
I am kinda surprised you cant find them at an auto parts store. Many newer cars use the same ones. I know my parts store delivered mine to my door within 5 minutes. If you cant find them, let me know, I can get them and I'll ship them to you at cost.
Nice Rumble
snappy said:my accesory fuse for heated shield seems to blow kind of easy.i cant find these 3 amp mini fuses anywhere(radio shack,auto part stores,or even e-bay)i hate to have to drive an hour and a half to dealer just for fuses!~
Ace hardware stores in NH carries them. I would think MA would as well.
ZR800EFI
I've hardwired to the jumper leads with an inline 3amp fuse and it blew. I also blew the 3amp for the accessory using the adaptar. Seems to have a better chance of blowing if you plug or unplug while the sled is running. If you do what you want to do with the sled off, they might not seem to blow...that's what a buddy told me that blew his a lot a year ago.
A couple weeks ago I put a 5amp in my hardwired connection, and 3 back in the accessory. I haven't used it yet, but I'll only use the hardwired one to see if it blows while the sled is running.
stoutner
- Dec 6, 2005
- Seneca Falls, NY
- www.ecsexpress.com
You can buy theses fuses just about anywhere. Walmart, Kmart, convenience store etc. Any autoparts store should have them. Your auto parts store must suck. Anywho...I run a 10 amp fuse int that slot.
Occasionally it has blown because I have my heated sheild wired into it and I have accidently ground the cord out. Other than that, it works great....and has for 3 years.
