hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Designed a torsion spring adjuster block for the Japan sleds but designed it to also fit the sidewinder and viper skids.
The Japan block and cat block are nearly identical on the amount of preload applied. I matched the Japan block, so will be slightly stiffer on all settings compared to the stock cat block.
From center of pivot, the japan settings are .426", .786", and 1.1856 " The cat block is .39", .75", and 1.13".
Overload position 4 is 1.669". This will be ideal for heavier riders, aggressive riding, and sleds with a seat jack.
Blocks are constructed of 6061 Aluminum and riveted together.
There is a 11/16" coupling nut pressed into the bock which is used to adjust the settings. By locating this off the pivot center line the block is much easier to turn as mechanical advantage is gained. The gained advantage plus use of steel coupling nut makes stripping adjustment nuts a thing of the past.
As an FYI, these will work on all yamaha japan torsion spring suspensions and all Viper and Sidewinder torsion spring skids as well.
Retail is going to be a bit a little cheaper than originally projected to. Will be selling them for $65 a set.
. I will get them in the online store soon.
You should contact Muffin Works.. they have a CAD dwg of a 5 position they sold but don't anymore.
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Is powder coating an option?
Sent from my SM-G920W8 using Tapatalk
geez150
Technical wouldn't those be a 5 way adjuster?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Yes I can get them powder coated. I will check tomorrow how much it would cost.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
The 5th position isn't used. If I add height to make position 5 any bigger it has Clearance issue on the fx nytro. I designed it to fit many models.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
$5 extra to powder coat a set black.
Jacob Sawchuk
- Dec 22, 2015
- Saskatchewan
- 2009 Nytro XTX
So how does a guy get ohold of one of these
Sent from my LG-H831 using Tapatalk
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
If in Canada just pm me an email address so I can send a paypal invoice. My store does not compute international shipping. Can ship these to Canada USPS for $23
For US customers order in the store.
http://www.barnofparts.com/apps/webstore/products/show/7257186
dennyboy
- Oct 4, 2013
- Minnesota
- 2012 nytro XTX 1998 srx 600
ordered mine 5 days ago and I can't wait!! is there a lead time for making them?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I apologize for the delay. I was not able to get much done last week as we were at hospital with our daughter. All is well again with her and I'm in overdrive trying to catch up. The blocks were dropped off at powdercoater yesterday, and should be done today.
On a side note I added markings to indicate position for some finishing touches to the final product!
- 7K
