Miller’swinder
- Dec 27, 2017
- 17’ Yamaha sidewinder
Just hit 500 kms on my sw. Going to change oil filter, engine oil, and chain case oil. Is there anything to be aware of when doing it?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
500km....so only 300 miles.
I only rode mine 2 times and have 300 miles....I usually do my first change and chain adjustment at 600 miles.
Is that what manual says now?
Thx
Dan
Thx
Dan
Bt04f250
- Mar 6, 2017
- IL
- 2018 sidewinder xtx 137 high Vis ordered 2012 Polaris rush pro r Le
Manual says 500 miles for first service I believe
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Dealer told me and stated in manual 800km(500mi) for first oil/filter change and drive chain tension- initial 500km (300mi) I go over the hole sled on my first service
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Thanks guys....I have always done all my sleds around 600-800 miles as we can rack them up very fast here, just a few rides to get us there.
I just thought 300 miles was rather early on....I know it cant hurt though.
Dan
Dan
Bt04f250
- Mar 6, 2017
- IL
Yeah my dealer said after 300 is fine but 500-600 is average.
Miller’swinder
- Dec 27, 2017
I would much sooner do it early just because my oil has sure went black. Just would feel better doing it now and then again before I put it away. That I’m my mind is how you keep a reliable motor in great shape.
Miller’swinder
- Dec 27, 2017
Glad I did mine as soon as I did. Found a turbo bolt laying in the belly pan under the engine.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I think the 17s had this issue....not sure if they fixed it for 18? I assumed so.Glad I did mine as soon as I did. Found a turbo bolt laying in the belly pan under the engine.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I had mine done @ 500miles. Then another going over @ 1000 which includes the chaincase lube R&R.
Miller’swinder
- Dec 27, 2017
I could tell by the looks of the bolt someone at the dealer was on the two easy bolts to tighten them. But the third one, Which was on the pan was brand new factory. (No marks on head) Nobody from the dealer had the time to look for the third one I guess
