number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
This is the driveshaft bearing located below the secondary clutch. Mine lasted 6,760 miles without being greased and it only spent 1 summer in storage. What year is your sled?
ApexerER
My sled is a 06 Apex ER.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
I would recommend changing it as it has sat for 2 summers. Mine showed no signs of failure other than about 2 minutes before it failed. My belt squeeled when I took off because it was having a hard time turning the track.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Here is my step by step on RE-GREASE of jack and drive shaft bearings,lots of pics....
as REX said,probably good to REPLACE after 3000 or so....im over 6000 now myself so i think this summer it will get ALOT of TLC....new bearings and Y pipes,and maybe even a chain,some new clutch springs,some idlers ect ect.......lots to keep up with when you have a motor that lasts many thousands of miles..
LINK to my RE-GREASE thread:
http://www.ty4stroke.com/viewtopic.php? ... ht=bearing
Dan
Dan
stoutner
- Dec 6, 2005
- Seneca Falls, NY
- www.ecsexpress.com
...or, you can just bring them to a bearing supplier and get new ones for about $12 each.
