marc001
- Sep 28, 2013
- Howard City MI
- 2014 Yamaha Apex SE 2017 Yamaha SideWinder LTX LE
2014 Apex SE with 6000 miles, anything I should look for or replace in the off season? This sled has been flawless, the best sled I have ever owned period (thank you Yamaha). I do the normal oil and filter change and repack bearings but didnt know if there was anything else to check for. How long do exhaust donuts last? Thanks.
About that long. I'd be changing them. The header/EXUP is VERY expensive so don't let the clamps get loose due to worn donuts and break the flanges.
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
I'd drop skid inspect repack and replace. I also installed Dupont slides at this time. If it was mine I'd have the shocks recharged per your weight and riding style. All though I like my sled as a 136 it was a 121 at one point in it's life. Big reason I went with 136 was to improve ride. Ride definitely better but still not what I was looking for. At the end of the day wish I would have tried revalve first but IMO 136 is better for trail riding for many reasons. Traction vs trenching and bridging bumps to name few.
marc001
- Sep 28, 2013
- Howard City MI
I changed my duponts at 5000 miles and my Apex has the float air shocks.I'd drop skid inspect repack and replace. I also installed Dupont slides at this time. If it was mine I'd have the shocks recharged per your weight and riding style. All though I like my sled as a 136 it was a 121 at one point in it's life. Big reason I went with 136 was to improve ride. Ride definitely better but still not what I was looking for. At the end of the day wish I would have tried revalve first but IMO 136 is better for trail riding for many reasons. Traction vs trenching and bridging bumps to make few.
trailanimal
I have the 2013 Apex se 128 with 12, 600 miles, so far all I've had to do at around 8,500 mile was change some bearings in the bogies and this year I had rubber coming off the 2 inside bogie wheels all others were good. This spring changed out bearings on the left side of the jack shaft and drive shaft. This year I also got my center shock rebuilt, will do the fronts for next year. In 5 years of hard riding never lost a pound in any shock. I put the DuPont sliders on at around 1,600 miles and they are still good with close to 11,000 on them they just stay right around 10 mm thick, can't get a 10mm wrench on them. When I put the sled away last week I pulled my track all the way around sitting behind with the back end up in the air and noticed it was falling apart so I will be putting a new ice attack on for next year. Oh at 8,000 miles I had to adjust the power valves to get them lined up, very easy to do, just make sure you don't get the cables to tight. Also put new slider buttons in the secondary clutch at this time. I also had to put new bushings on my sway bar, the left one was worn, right one still good, all others still tight. That's it in 5 years of 2,000 to 3,000 miles every year. I grease the suspension before each ride and blow compressed air in the clutches every second week as well as cleaning the belt, gets me away from the tv. Just before I put her to bed for the summer while I was running some K100 through the engine at idle I put my gloved hands over the exhaust and the engine stopped in a nano second, so I guess my donuts are OK, Might change them for next season, so that I'll know I'm good for another 12,000. It really has been an incredible sled. All my friends who bought cats and doos at the same time are on there second sled.
