8 teeth extrovert drivers gearing
jr13322
London, Ontario
Just looking for some opinions out here on gearing changes with 8 teeth extrovert drivers. In the process of extending 08 GT to a 144 inch, 1.5 crossover track. Changing drivers to 8 teeth drivers for more clearance. What type of gearing changes should I be looking at?
I have 8 teeth extrovert drivers in my attak. I changed the top gear to a 25 tooth gear and it is pretty close to the stock gearing in the attak. and you can use the same chain.
Dealer is sugesting to go with 21/38 gearing due to extended track and thicker lug... sounds right to me, what do you guys think?
you would be gearing down even more with that set up, you need to go the other way with gearing as the 8th drivers are gearing you down.
