99 Wolverine Carb Trouble
saweetlou
So long story short, I pulled the carb on my bike to clean it and had an issue with the diaphram on top of the carb. It turns out that because I used carb cleaner it expanded the diapharm and in turn would not fit back in, I then took a torch and shrunk it back to size reinstalled it and the bike started and ran fine, I then decided to remove the fuel tank to clean it out due to a lot of dirt in it. Well I put it all back together with fresh gas and fired it up. It runs and idles fine but now as soon as I give it gas it dies. I made sure the parking brake wasnt engaged so thats not it I also pulled the bowl and jets to blow a little air through them and it still runs the same.
What gives.
Just follow the wires down and unplug the switch to be sure that's not the problem. Believe me the switch sticks. Been there done that.
