I noticed some free play on all the A Arm bushings . Just wondering if there is a bushing kit available and how do you get to the nut on the engine side of the bolt.. Can you get to it from underneath ?? Thanks
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
ulmers sell a set of god bushings Look them up in the vendor section
apex yooper
Yamaha sells them also.
danq
You get to the lower a-arm nuts from the top. Air box, battery come out. Make the update when you do an oil change....
YAttak07
Just installed the Ulmers kit and WOW what a difference. Went from sloppy movement to nothing at all. Original bushings were made of a cheap plastic material?? Ulmers kit is made by Oilite I think as they look like brass and may be oil impregnated??? Should last a lot longer than stock.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
We have complete front end bushing kits in stock. It includes 24 bushings total and eliminates virtually all the slop in the a-arms. Our bushings are an oil impregnated bronze and are sized to much tigher tolerances than stock as well.
TechMaples
- Nov 9, 2007
- Monticello, ME
- 16 Zr 8. 20 Riot 8. 98SRX
- Monticello
Save yourself alot of future wrenching and buy ulmers!
Yamaha ones are loose new.
ulmers are way better.
mmaxcarver
Great Service....
I just got mine today for the Nytro, thanks for the super quick service!!!
I just wish me installing them would be just as quick....
Srxspec said:We have complete front end bushing kits in stock. It includes 24 bushings total and eliminates virtually all the slop in the a-arms. Our bushings are an oil impregnated bronze and are sized to much tigher tolerances than stock as well.
jkenosh
i put in the ulmer kit and was amazed by the difference, one of the best upgrades ive made and alan is a standup guy
kit is great, very tight, go one step further and drill adn tap everything for grease fittings, they will probly never wear out.
great kit, fast service.
berge75
+1 on the fittings. Will never need bushings again.
nb-attak
how long or big of a job is it to change those bushings. i had the fron end lifted to change carbides and saw the amount of free play in the a-arms.
Chasx7
- Dec 4, 2005
- Hesperia, MI
- 1997 700SX, 2002 Viper, 2008 Apex GT, 2015 Polaris 800 Pro-R Switchback
nb-attak said:how long or big of a job is it to change those bushings. i had the fron end lifted to change carbides and saw the amount of free play in the a-arms.
I just greased all my stock A-arm busings yesterday (sled is new) and you basically have to take the sled apart to about where you do an oil change as the lower right A-arm bolt is really buried.
it will take about 2-3hours to do this. just wait till your changing your oil and it is only another 1hr or 2.
