sethryder
- Feb 19, 2014
- Derry NH
- 07 phazer fx
Hey there,
After installing ulmer a-arm bushings the collars (long tubes inside arms) on my upper a-arm were such a tight fit in the new bushings that i had to tap them in with a mallet. Now the collars i doubt will rotate inside the a-arms so the a-arm movement will be the collars rotating on the a-arm bolts themselves (make sense?) That seem fine or is there something further i need to do?
Thanks,
Seth
Thanks,
Seth
I just did the same bushing kit in my nitro and had to tap in some of the collars too.....its all good... great fit...
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Same with mine, had to tap it in with a mallet. they wear in quick and after 4000 miles still have an almost perfect fit.
