CaptCaper
- Jan 1, 2007
- Northern N.H.
I got 10K never broke a shaft and studded with 162 studs. I am a big boy ( 250lbs plus gear) carry also another 150lbs of gear like winch,hyjack, rope,shovels,etc.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Does this mean that my OEM drivers will not fit on the micro-belmont shaft? If so, I am assuming that the aftermarket shaft is sold with aftermarket drivers?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
I put an 11' shaft w/extro drivers in my 07' Apex, you just have to cut shaft and tap the threads.
Blue Dave said:Does this mean that my OEM drivers will not fit on the micro-belmont shaft? If so, I am assuming that the aftermarket shaft is sold with aftermarket drivers?
Actually they do fit....very tight in fact. If you are going with micro-belmont, just get the whole set-up from ulmer, as he will press the drivers on for you in the correct spot, and then ship out the whole assembly. Just for the sake of human error, I would double check the dimensions of the drivers before installation as it is very important to have the spacing correct.
