kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Hey guys, looking to insulate a plastic tank from the exhaust heat near the rear of the sled, already has a heat shield in place so it not like its next to a turbo just want more insurance nothing melts as its full of fuel! Any links to good stuff that will stick to plastic, aluminum, etc?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
I use a fibreglass textile coated in aluminum on one side. It's made from the same material as header wrap. Glue it to the tank with the aluminum out. I have added a few layers for good measure.
I have also removed all aluminum heat shields and replaced then with custom made shields made out of this material to cover the header, turbo, downpipe and fuel tank. The material is available in large sheets like 3 by 4 feets or even larger.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
rxrider said:I use a fibreglass textile coated in aluminum on one side. It's made from the same material as header wrap. Glue it to the tank with the aluminum out. I have added a few layers for good measure.
X2
kinger
- Jan 17, 2005
- Clear Lake, IA
Any links?
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
kinger said:Any links?
Or you can purchase a Turbo Blanket, see my member pic. I have had it on for two seasons, works great!
http://www.rallysportdirect.com/PTP-Tur ... GoogleBase
FLYBYU
Omega_5
It's not adhesive, but here is how I extra insulated the heat shield on my Nytro.
When I had the shield off, I cut 4 equal length pieces of fiberglass wrap, riveted them to the top of the shield.
I had to stick my hand in there to adjust the throttle cable a few weeks back, it barely gets warm under the tank.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
I also run a Garrett turbo blanket in addition to the fabric. I bought the fabric locally here in Norway, don't know the manufacturer. Every Automotive turbo car shop should have it in stock.
