RxThunder
I'm sure there must be a type of spanner wrench for adjusting preload on these things, I have always just sprayed them down with WD 40 and used a punch and hammer and lightly tapped them around the adjust preload. I was doing this on my 06 Apex Gt rear shock and it seems like the first coller is almost a type of plastic material? or really soft metal, just wondering how everyone adjusts these on their sleds. I need some more preload in the back bad, I think I just need a bigger spring, but I want to see what I can get out of this one while keeping it in spec so I don't have coil bind.
There is a wrench for that. Usually found in the factory tool kit. I use a strut spring compressor and compress the spring and then adjust the preload nuts. Less chance of wrecking them this way.
Do you know what spring you have?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
The wrench sucks...best way is the way you've been doing it. Maybe use a piece of hardwood instead of the punch.
Using the spanner wrench is not friendly on your knuckles.
RxThunder
It's still the stock spring for a 06 Apex Gt, shock has been revalved. I doubt I will be able to get enough preload out of it for how I like to ride.
- Jun 28, 2004
- Clinton, Wi.
Brass key stock. I used a piece of 3/8 x 8" long. Doesn't mar up your lock collar and bites instead of slipping.
As you know, more spring is really required on the GT. The main adjuster nut is a fiber reinforced plastic. It has plenty of up sides... The down side (?) is that one really needs to use the wrench. I can supply both if you are interested (TY Advertiser in the works).
- 13K
