AEM Wideband just hangs at 14.6 , wont change
RXB-1
Eastern Oregon
I Have a bender rear mount and can change up the pitot and make the sled run different but my AEM just hangs at 14.6 like it is stuck. sometimes I might get a slight bit of movement but it does not change while moving through the RPM range. The sled runs good plug color is good ( not too lean) . Sensor is mounted after the turbo and has done this since new.
Any ideas
Sounds like the sensor is unplugged. If you power up the gauge without the sensor connected it will go to 14.6-14.8 to show the gauge is working.
Wiring problem somewhere. Generally if the sensor is bad it will go to full lean after the sensor warms up.
