zackn291
I want to get a set of bars, probably renthal but I'm kinda stuck with what I need to do to keep my stock hand warmers. So how do I got about keeping the stock grips on there? like their is a rivet holding them on so should I drill a hole in my new bars and rivet them or would some good ol grip glue work? and ofcourse keep the warmers in good working condition.
prozac500
The stock grips are glued on I had a hard time geting them off I had to cut them off. So I had to buy new grips. I got mine form RSI and the hi power grip heater elements.
Here is the link
http://www.rsiracing.com/product_info.p ... cts_id=207
Here is another link
http://www.rsiracing.com/product_info.p ... cts_id=182
Here is the link
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
I love RSI's bars and gell grip tape!!!
zackn291
Thanks. I'm sure a little compressed air will get the grips off.
LJ 452
If you get them off with compressed air you may be the first in history. I changed out the ones on my Nytro last year and there was no way to cleanly remove. Some ethol methol bad stuff might do the trick but it may also damage the material. Good luck. If you go with the RSI make sure to glue them on, I just put them on with air and they would slowly work their way off, ended up burning up an element, I think because of the twisting and rubbing from the grip slipping.
zackn291
How hard is it to wire up these heating elements? What exactly do you have to do?
