aftermarket transfer rods
Here you go, I believe the Maxx Perf rods are the best on the market...BBY
THE ORIGINAL ADJUSTABLE CONTROL ROD
Maxximum Performance Quick Rods are the ORIGINAL and EASIEST to use adjustable control rod available for your Yamaha Pro-Action suspension. The Hand Adjustable Quick Nuts literally can be adjusted in seconds-without tools, stay in place, and will not freeze even in the harshest conditions. Suspension removal is not necessary for installation. Quick Rods are designed so you not only can you increase weight transfer (ski lift) from stock but you can also decrease weight transfer from stock, allowing you to quickly dial in the suspension to the amount of traction and handling that best suites your riding style or situation. If you're riding tight trails you can set them for improved handling. If you pull out on the lake and what to race, just reach down, adjust the nuts for traction and you're ready in a matter of seconds. A series of reference lines on each rod makes setting easy, and shows you how you have them set. Quick Rods also work excellent for mountain riding, letting you increase or decrease the amount of ski lift for hill and snow conditions. If you have a set of our original double nut style Quick Rods you can order the Quick Nuts separate, and they will directly replace the two locking nuts. The new SX-VIPER stock rod only has 7.5mm of adjustment. We are offering a hand adjustable nut, for those of you who feel this is sufficient and want hand adjustable nuts to go on the stock SX-VIPER rod. Quick Rods are many times stronger than the stock rods (which have been known to bend or break) because of their solid chrome moly construction, and because they have less moving parts they are lighter (and do not freeze) like other (inferior) designs of adjustable control rods. Quick Rods fit all '97 and newer models including XT, XTC, SX, SRX, Vmax, Mountain Max, Phazer 500 and SXVIPER. On the new SX-VIPER, we also recommend 10mm spacers be installed with the Quick Rods.
QCKSX1-HA Quick Rods with Quick Nuts,
Fit all except '00-'02 Mountain Max and SRX .......................$129.95
QCKSRX-HA Quick Rods with Quick Nuts,
Fit '00-'02 SRX & Mountain Max ........................................$129.95
QCKNUT Quick Nut set (Maxximum rod only) ........................$49.95
VP-QCKNUT VIPER stock rod only ......................................$49.95
90202-16232-00 Spacer for SX-VIPER
4 Required .....................................................................$2.42 each
You can also just get the nuts that Powerhaulic is talking about. They look like the nuts on the rods shown below and will fit your stock control rods. They sell for $49.95
ive used several sets like benders,haucks etc..
the ones made by advant-edge are by far the easiest and best quality
i think they make the max perf quick rods too,right bby?
